399
Alex Kafando 发表于 2026-9-28 23:37  Okay, here is my wirin ...
举报
34
TL_SUNPENG 发表于 2026-9-29 09:49 The wiring is correct. Could you share your firmware so I can try to reproduce the issue on a deve ...
Alex Kafando 发表于 2026-9-29 15:48 Thank you. I will try the programmer firmware. Is it compatible with Programmer V1-V3 (pid\_8266)? A ...
Alex Kafando 发表于 2026-9-29 16:28 Update: Re-enable Debug-interface now returns 'ok' consistently - the issue was a bad physical con ...
TL_SUNPENG 发表于 2026-9-29 16:52 Once Re-enable succeeds, you can go ahead and download the program again — no need to run Activat ...
Alex Kafando 发表于 2026-9-29 18:10 Thank you so much for your help throughout this thread! I can confirm the issue is fully resolved. ...
本版积分规则 发表回复 回帖后跳转到最后一页
