查看: 351|回复: 3
Zigbee BLE Concurrent - BLE issue
超凡大师
发表于 2026-8-12 06:21:14 | 显示全部楼层 |阅读模式 来自 澳大利亚
芯片型号: TL7218
SDK及版本: telink_zigbee_ble_concurrent_sdk-2.4.1.0
I am trying to build SampleGW app with added BLE security.
I added the following in user_ble_init(void){}
blc_smp_setSecurityLevel(LE_Security_Mode_1_Level_4);
            blc_smp_setSecurityParameters(Bondable_Mode, 1, LE_Secure_Connection, 0, 0, IO_CAPABILITY_DISPLAY_ONLY);
            blc_smp_setDefaultPinCode(123456);
After trying to build I get the following error:
<artificial>.text.blt_smp_sc_handler+0xaec): undefined reference to `eccp_pointVerify'
/cygdrive/c/TelinkIoTStudio/RDS/V5.3.x/toolchains/nds32le-elf-mculib-v5f/bin/../lib/gcc/riscv32-elf/12.2.0/../../../../riscv32-elf/bin/ld.bfd: //cygdrive/c/Users/Wieslaw/AppData/Local/Temp/cc8tFlku.ltrans5.ltrans.o: in function `.L1438':
<artificial>.text.blt_smp_sc_handler+0xb0c): undefined reference to `eccp_pointMul'
/cygdrive/c/TelinkIoTStudio/RDS/V5.3.x/toolchains/nds32le-elf-mculib-v5f/bin/../lib/gcc/riscv32-elf/12.2.0/../../../../riscv32-elf/bin/ld.bfd: /cygdrive/c/Users/Wieslaw/AppData/Local/Temp/cc8tFlku.ltrans6.ltrans.o: in function `.L569':
<artificial>.text.blt_ecc_gen_key_pair.constprop.0+0xd8): undefined reference to `eccp_pointMul'
collect2: error: ld returned 1 exit status
Compilation fails on this function: blc_smp_setSecurityParameters(Bondable_Mode, 1, LE_Secure_Connection, 0, 0, IO_CAPABILITY_DISPLAY_ONLY);
What is wrong? When I try to compile BLE part in just BLE SDK there is no problem.
发表于 2026-8-12 11:41:12 | 显示全部楼层 来自 上海
libdrivers_tl721x.a (1.28 MB, 下载次数: 2)
The tl721x driver library is missing some files, please try and use this new driver library file.
21
超凡大师
 楼主| 发表于 2026-8-13 05:52:50 | 显示全部楼层 来自 澳大利亚
Thank you very much for your help. It worked.
By the way, I noticed that your website misses English translation. For example It has 回复 instead of REPLY... etc.
The other thing I noticed on your Github https://github.com/telink-semi/telink_zigbee_sdk/tree/master Zigbee SDK shows as upgraded to version 4.0.1.0 but it is not Zigbee SDK. If you look in PLATFORM folder it doesn't have all the chips that Zigbee SDK supported. In the STACK folder there are folders like ble, ieee802154, zigbee, zigbee_direct. TL7218 supports Zigbee Direct so why isn't it in the platform folder?
Is there a Zigbee Direct SDK on the GitHub that supports TL7218?
发表于 2026-8-13 11:00:15 | 显示全部楼层 来自 上海
Thanks for your feedback. The v4.x is an all-in-one SDK, and tl721x might be added in the next version.
