查看: 4|回复: 0
U4GM's Diablo 4 Season 14 Barbarian Strategy
发表于 2 小时前 | 显示全部楼层 |阅读模式 来自 安徽宿州
Mythic Gear Is Easier to Chase, but It Still Has to Earn Its SlotSeason 14 feels different now that the July updates have opened up more reliable Mythic routes. The crafted-item limit is gone, Corrupted Reaper runs have more appeal, and Mythic Tribute of Armaments has real weight in the Undercity, especially once you can handle the upper Torment tiers. That said, I would not start by stuffing every purple drop into a Barbarian's gear slots. A solid character still begins with Fury control, Shout uptime, and a damage skill you can keep using when the screen gets crowded. Even Diablo 4 runes are worth considering as part of that wider setup, since a useful build is about how its pieces work together, not how rare they look in isolation.
Frenzy and Whirlwind Make a Sensible Everyday PairFor general farming, I like a Frenzy-led Whirlwind approach because it gives you something to do when Fury gets tight. Frenzy builds momentum, helps with attack speed, and keeps the character from feeling flat between larger pulls. Then Whirlwind takes over when enemies stack up or when moving through a dungeon matters more than standing still. Rallying Cry is the skill that often saves the rhythm. Challenging Shout handles the moments where elite packs start hitting harder than expected. Wrath of the Berserker is your push button, not something to press the second it comes off cooldown. You'll notice the difference when you hold it for a boss, a packed room, or a rough objective. Season 14's stronger Raging Frenzy and improved Battle Trance make this style more tempting than it was before, though Fury gained from taking hits is no longer something you can lean on forever.
Pick Mythics for the Problem You Actually HaveRing of Starless Skies is usually the cleanest first choice for a Whirlwind player who keeps running dry. More time spinning means more real damage, even if another item looks better on a character sheet. Harlequin Crest is appealing for its six ranks to all skills, but it no longer brings the old defensive comfort, so it's not an automatic pick for a fragile build. The Grandfather can still be excellent when your weapon arrangement supports it, yet replacing a useful Aspect can hurt more than people expect. Tyrael's Might is the practical option when survival is holding back your runs. Selig can work too, but only if you've built around its resource pressure. Before feeding a good Unique into the Horadric Cube, stop and look twice. The current recipe keeps the slot, not the exact item, and that can turn a promising weapon into a disappointing gamble.
At Torment X, fast clears and repeated Undercity runs are usually the sensible routine. At Torment XII, the guaranteed Mythic from an Armaments tribute gives every completed run a clear purpose, but it doesn't mean every reward belongs in your loadout. Test changes over several runs. Watch how long a boss takes, how often Whirlwind falls apart, and whether your defensive skills are ready when trouble starts. If an item adds a little peak damage but leaves you starved for Fury, it's probably not helping. Keep your farming costs sensible too; having cheap Diablo IV Gold available for rerolls and upgrades can make it easier to test a promising piece without forcing rushed decisions.
GMT+8, 2026-7-24 20:10 , Processed in 0.079625 second(s), 21 queries .
