查看: 4|回复: 0
Smart Spaceport Routes for Arc Raiders | U4GM
发表于 3 小时前 | 显示全部楼层 |阅读模式 来自 安徽宿州
How should I approach Walking the Grid at Spaceport without wasting a whole raid?Start by treating the mission like the reason you deployed, not something you'll get around to after looting. Bring only what helps you move, recover, and get out. If you need room for supplies or mission finds, ARC Raiders Items can fit into a sensible plan, but there's no need to turn a focused trip into a huge haul. Once you're near the objective area, slow down. Listen for metal footsteps, distant shots, and doors opening nearby. Spaceport has lots of places where players drift into the same building from different directions. That's where runs go sideways. Check the mission text before you start poking through every room. If an interaction is available, do it when the area is calm enough, then move away before reading every new detail. Standing in front of a panel while staring at the screen is how people get caught out. You'll also want a route in your head before you cross open ground. It doesn't need to be perfect. Just know which bit of cover you're heading for if something starts firing. The shortest line on the map isn't always the safest one. A slightly longer path through cover often saves ammo, healing, and nerves.
Is it worth fighting other Raiders or every ARC patrol while doing Walking the Grid?Usually, no. That doesn't mean you should freeze whenever you hear someone nearby. It means you should ask whether the fight actually clears your path or just creates a louder problem. A patrol blocking a doorway may need dealing with. One wandering two buildings away probably doesn't. People often burn through ammo because they feel they have to clear the area first. Then another Raider hears it all and turns up when they're reloading. If you meet someone who seems to be doing the same mission, keep your distance and watch what they do. Some players are happy to pass through without trouble, especially if both sides are clearly focused on the objective. Still, don't assume anything. Leave yourself an exit and avoid crowding them in a tight room. In a squad, this gets easier if one person handles the mission point while the others watch entrances. Solo, it's more about timing. Wait a few seconds, listen again, then commit. After progress updates, don't let loot pull you deeper into Spaceport. Grab what's directly on the way, skip the detour, and head for extraction. If you've completed the task and made it out with ARC Items that support your next run, that's a solid result, even if your pack isn't full.
GMT+8, 2026-7-24 20:11 , Processed in 0.081529 second(s), 21 queries .
