查看: 4|回复: 0
[BLE SDK] Beat Benedictus In Path of Exile 2 Using This U4GM Boss Guide
发表于 3 小时前 | 显示全部楼层 |阅读模式 来自 江苏
Benedictus, First Herald of Utopia is one of the most memorable campaign bosses in Path of Exile 2. You'll encounter him at the end of The Excavation in the Arastas region during Act 4, and defeating him is required to continue the main story, unlock The Forge, and move one step closer to confronting The Beast.
This fight is a noticeable difficulty spike. Benedictus combines hard-hitting physical attacks with dangerous lightning mechanics, forcing players to pay attention to positioning instead of simply dealing damage. Before entering the arena, it's also a good time to invest some POE 2 Orbs or other Path of Exile 2 Currency into upgrading your gear, as a few defensive improvements can make the encounter much more manageable.
Prepare Before the Fight
Going into the battle with the right defenses is just as important as having enough damage.
Prioritize These Stats:
• High Lightning Resistance
• Solid Physical Damage Mitigation (Armor or other defensive layers)
• Enough Life to survive heavy hits
• A reliable movement skill like Dodge Roll or Dash
If possible, equip:
• Topaz Rings for extra Lightning Resistance
• Defensive runes or crafted modifiers
• A weapon that's been recently upgraded
Spending a small amount of POE 2 Currency on resistance gear is often far more valuable than chasing extra damage for this encounter.
Phase One: Shrinking Arena and Falling Debris
The opening phase is relatively straightforward, giving you a chance to deal as much damage as possible before the arena becomes more dangerous.
Once Benedictus reaches roughly half health, the fight changes significantly.
What Happens:
• Pillars appear around the edge of the arena.
• The available fighting space becomes smaller.
• Large rocks begin falling from above.
• Lightning structures start filling the battlefield.
The falling rocks don't always have obvious warning indicators, so avoid standing still for long periods. Small movements are usually enough to stay safe.
Phase Two: Maze Mechanic
The second phase is where most players struggle.
At certain points, Benedictus becomes temporarily untargetable and moves to one side of the arena while a glowing maze appears.
Your objective is simple:
• Find the correct path.
• Reach the glowing exit.
• Avoid getting trapped when the maze explodes.
Trying to rush without looking usually leads to unnecessary deaths.
How to Handle It:
• Stay fairly close to Benedictus before he begins the mechanic.
• Look for openings instead of running immediately.
• Save your movement skill for emergencies.
• Stay calm—the maze gives you enough time if you react early.
Lightning Laser Attack
One of Benedictus' most dangerous abilities is his sweeping lightning beam.
During this sequence he summons electrical orbs before firing a powerful laser across the arena.
But, the safest strategy is surprisingly aggressive.
• Stay close to the boss whenever possible.
• Move behind him during laser attacks.
• Use your dodge or movement skill to pass through him if necessary.
• Avoid running to the outer edge of the arena unless you have no other option.
Players who remain nearby usually have an easier time avoiding the beam than those trying to fight from maximum range.
Common Mistakes
Many failed attempts come from the same avoidable errors.
Try not to:
• Ignore Lightning Resistance.
• Stand still after attacking.
• Waste movement skills before major mechanics.
• Focus entirely on damage while ignoring arena hazards.
• Leave electric pillars active for too long.
Learning the attack patterns is far more important than trying to burst the boss down.
Rewards for Learning the Fight
Although Benedictus can feel overwhelming during your first attempt, he's designed to teach several core mechanics that become increasingly important later in Path of Exile 2.
Once you understand the rhythm of each phase, the fight becomes much more consistent and rewarding. With upgraded equipment, smart use of POE 2 Orbs, and a few well-chosen gear improvements purchased or crafted using Path of Exile 2 Currency, Benedictus transforms from a frustrating roadblock into one of Act 4's most enjoyable boss encounters.
As a trusted gaming service platform, U4GM.com helps players stay up to date with Path of Exile 2 guides, builds, and in-game details. You can also find exclusive offers on buy Path of Exile 2 Orbs.
GMT+8, 2026-7-23 17:33 , Processed in 0.089763 second(s), 26 queries .
