查看: 3|回复: 0
U4N Guide: How to Find the Hidden ARC Raiders Broken Monument Loot
发表于 1 小时前 | 显示全部楼层 |阅读模式 来自 江苏
Surviving a drop into the Dam Battlegrounds requires strategic navigation and top-tier loadouts. In the Broken Monument quest, you must locate and retrieve three specific quest items hidden in the hazardous Scrap Yard. Venturing into these high-threat locations with weak equipment is an easy way to get eliminated by lurking machines and hostile players. Equipping yourself with superior ARC Raiders Items from a reliable source like U4N is the best way to safeguard your journey, giving you the extra resilience and firepower needed to protect your inventory.
Locating these items quickly and extracting safely is the only way to progress. Let us go over the perfect pathing to get you in and out with your loot.
Scouting the Dangerous Scrap Yard Coordinates
The quest objectives are located within the Scrap Yard, a dense sub-region packed with twisted metal, piles of tires, and broken-down vehicles. To find it, open up your map and locate the area directly south of the Research and Administration Building and the Testing Annex, in the southern/southwestern portion of the Dam Battlegrounds map. Because this small yard is highly cluttered with cover, it is a hotbed for sudden ambushes. Keep your weapon ready and check your surroundings before moving between piles of scrap.
Locating and Collecting the Three Specific Containers
Inside the Scrap Yard, you must locate three yellow-marked wooden crates to find the mission-essential items. Note that opening these boxes drops the items onto the ground, meaning you must manually pick them up so they appear in your backpack.
First, make your way to the northern section of the Scrap Yard to find the small Field Depot structure, also known as the Raider Camp. Inside, you will find the Old Field Rations. Next, move toward the center of the Scrap Yard near the large cylindrical container tubes and broken fuel trucks to grab the First Wave Video Tape. Finally, navigate to the back of the wreckage field, tucked between a row of ruined cars and a large spherical tank, to retrieve the First Wave Compass.
Surviving the Run and Reaching the Extraction Point
The main difficulty of the Broken Monument quest is the strict survival rule. You must extract all three items in a single, successful run. If you get taken down before reaching an exit, all collected items will drop, forcing your quest progress to reset completely.
Avoid unnecessary combat as soon as your backpack is full and prioritize a stealthy, defensive route to the nearest extraction point. If you struggle to survive these high-stakes extraction runs and lose your favorite gear, you can choose to use the reliable services at ARC Raiders Loot buy options on U4N to instantly replenish your weapons and supplies, allowing you to quickly jump back in and hand over your loot to Tian Wen in Spiranza.
GMT+8, 2026-7-16 16:34 , Processed in 0.088586 second(s), 22 queries .
