查看: 561|回复: 3
[IDE工具] tc_ble_mesh-V4.1.1.0 vscode 编译错误
发表于 2026-6-23 11:12:05 | 显示全部楼层 |阅读模式 来自 广东
cmake configure
-- Project: tc_ble_mesh_b85
-- language: c
-- Target NUM: 17
-- Target: 8258_bootloader
-- Target: 8258_mesh
-- Target: 8258_mesh_gw
-- Target: 8258_mesh_gw_node
-- Target: 8258_mesh_lpn
-- Target: 8258_mesh_monitor
-- Target: 8258_mesh_switch
-- Target: 8258_spirit_LPN
-- Target: 825x_ble_sample
-- Target: 825x_master_kma_dongle
-- Target: lib_sig_mesh_825x
-- Target: lib_sig_mesh_gw_node_825x
-- Target: lib_sig_mesh_LPN_825x
-- Target: lib_sig_mesh_monitor
-- Target: lib_sig_mesh_prov_825x
-- Target: liblt_8258_kma_dongle
Error: CMake Warning at CMakeLists.txt:180 (message):
  Path does not exist:
  D:/tc_ble_mesh-V4.1.1.0/firmware/drivers/B85/driver_ext/driver_lib
Call Stack (most recent call first):
  CMakeLists.txt:317 (include_sources)
-- Target: liblt_8258_mesh
-- Configuring done (0.7s)
Error: CMake Error: Cannot determine link language for target "lib_sig_mesh_825x".
Error: CMake Error: CMake can not determine linker language for target: lib_sig_mesh_825x
Error: CMake Error: Cannot determine link language for target "lib_sig_mesh_gw_node_825x".
Error: CMake Error: CMake can not determine linker language for target: lib_sig_mesh_gw_node_825x
Error: CMake Error: Cannot determine link language for target "lib_sig_mesh_LPN_825x".
Error: CMake Error: CMake can not determine linker language for target: lib_sig_mesh_LPN_825x
Error: CMake Error: Cannot determine link language for target "lib_sig_mesh_monitor".
Error: CMake Error: CMake can not determine linker language for target: lib_sig_mesh_monitor
Error: CMake Error: Cannot determine link language for target "lib_sig_mesh_prov_825x".
Error: CMake Error: CMake can not determine linker language for target: lib_sig_mesh_prov_825x
Error: CMake Error: Cannot determine link language for target "liblt_8258_kma_dongle".
Error: CMake Error: CMake can not determine linker language for target: liblt_8258_kma_dongle
Error: CMake Error: Cannot determine link language for target "liblt_8258_mesh".
Error: CMake Error: CMake can not determine linker language for target: liblt_8258_mesh
Error: CMake Generate step failed.  Build files cannot be regenerated correctly.
-- Generating done (0.7s)
Command exited with code 1
 楼主| 发表于 2026-6-23 12:03:57 | 显示全部楼层 来自 广东
删除这些 Target 后正常
发表于 2026-6-23 15:41:31 | 显示全部楼层 来自 上海
可能这个工程还未做适配, 这些lib开头的应该是用于生成库的, 插件尚未实现这个类型的target转换. 如果不影响你的开发需求, 可以按你目前的解决方法.
 楼主| 发表于 2026-6-23 16:09:37 | 显示全部楼层 来自 广东
TL_WXS 发表于 2026-6-23 15:41
可能这个工程还未做适配, 这些lib开头的应该是用于生成库的, 插件尚未实现这个类型的target转换. 如果不影 ...
没啥影响,目前按这种方法解决。
另外,插件和 Telink Iot Studio 生成的目录深度不一样,post-build steps,tl_check_fw.sh,里面 tl_auth_check_fw.exe 是相对路径,会导致找不到程序
