查看: 1231|回复: 4
Can I modify zdp client functions ?
璀璨钻石
发表于 2026-2-3 10:01:58 | 显示全部楼层 |阅读模式 来自 韩国
SDK及版本: Concurrent SDK v2.4.1.0
Can I modify zdp client functions like zdo_bindOrUnbindIndicate() ?
const zdp_funcList_t g_zdpClientFunc[] = {
        {NWK_ADDR_REQ_CLID,                                  FALSE,        zdo_nwkAddrIndicate},
        {IEEE_ADDR_REQ_CLID,                                  FALSE,        zdo_ieeeAddrIndicate},
        {NODE_DESC_REQ_CLID,                                 FALSE,        zdo_descriptorsIndicate},
        {POWER_DESC_REQ_CLID,                                 FALSE,        zdo_descriptorsIndicate},
        {SIMPLE_DESC_REQ_CLID,                                FALSE,        zdo_descriptorsIndicate},
        {ACTIVE_EP_REQ_CLID,                                 FALSE,        zdo_activeEpIndicate},
        {MATCH_DESC_REQ_CLID,                                 FALSE,        zdo_matchDescriptorIndicate},
//        {COMPLEX_DESC_REQ_CLID,                           FALSE,        zdo_complexDescIndicate},                //DEPRECATED
//        {USER_DESC_REQ_CLID,                                FALSE,        zdo_userDescIndicate},                        //DEPRECATED
#ifdef ZB_ROUTER_ROLE
        {DEVICE_ANNCE_CLID,                                        FALSE,        zdo_deviceAnnounceIndicate},
        {PARENT_ANNCE_CLID,                                        FALSE,        zdo_parentAnnounceIndicate},
#endif
        {SYSTEM_SERVER_DISCOVERY_REQ_CLID,        FALSE,        zdo_SysServerDiscoveryIndicate},
        {END_DEVICE_BIND_REQ_CLID,                        FALSE,        zdo_endDeviceBindIndicate},
        {BIND_REQ_CLID,                                                TRUE,        zdo_bindOrUnbindIndicate},
        {UNBIND_REQ_CLID,                   TRUE,        zdo_bindOrUnbindIndicate},
        {MGMT_LQI_REQ_CLID,                                        FALSE,        zdo_mgmtLqiIndicate},
        {MGMT_BIND_REQ_CLID,                       FALSE,        zdo_mgmtBindIndicate},
        {MGMT_LEAVE_REQ_CLID,               TRUE,        zdo_mgmtLeaveIndicate},
        {MGMT_PERMIT_JOINING_REQ_CLID,                FALSE,        zdo_mgmtPermitJoinIndicate},
#endif
        {MGMT_NWK_UPDATE_REQ_CLID,                    FALSE,        zdo_mgmtNwkUpdateIndicate}
发表于 2026-2-4 16:53:20 | 显示全部楼层 来自 上海
You can use your new function instead of original function, like as zdo_userDescIndicate().
But at the same time, you need to pay special attention to the use and release of zbbuf.
33
璀璨钻石
 楼主| 发表于 2026-2-5 07:18:34 | 显示全部楼层 来自 韩国
But at t ...
Can I get original code ?
33
璀璨钻石
 楼主| 发表于 2026-2-5 07:19:25 | 显示全部楼层 来自 韩国
But at t ...
发表于 2026-2-6 20:39:05 | 显示全部楼层 来自 上海
A simple example code is as follows.
void zdo_userDescIndicate(void *buf)
    zb_buf_t *zbuff = buf;
    aps_data_ind_t *ad = buf;
    u8 *payload = ad->asdu;
    u8 seqNum = *payload++;
    u16 nwkAddrReq;
    COPY_BUFFERTOU16(nwkAddrReq, payload);
    payload += 2;
    zdo_zdp_req_t zzr;
    TL_SETSTRUCTCONTENT(zzr, 0);
    u8 offset = OFFSETOF(zdo_user_descriptor_resp_t, user_desc);
    TL_BUF_INITIAL_ALLOC(zbuff, offset, zzr.zdu, u8 *);
    u8 *ptr = zzr.zdu;
    *ptr++ = seqNum;
    *ptr++ = ZDO_NOT_SUPPORTED;
    COPY_U16TOBUFFER(ptr, nwkAddrReq);
    ptr += 2;
    *ptr++ = 0;//length
    zzr.cluster_id = USER_DESC_RSP_CLID;
    zzr.zduLen = ptr - zzr.zdu;
    zzr.buff_addr = buf;
    zzr.dst_addr_mode = SHORT_ADDR_MODE;
    zzr.dst_nwk_addr = ad->src_short_addr;
    zzr.zdoRspReceivedIndCb = NULL;
    zdo_send_req(&zzr);
    zb_buf_free((zb_buf_t *)zzr.buff_addr);
