查看: 1118|回复: 1
[Others] How to enter bootloader mode and burn firmware into TLSR8208
发表于 2026-1-23 22:14:17 | 显示全部楼层 |阅读模式 来自 印度
芯片型号: TLSR8208
I haven't found anything useful in the datasheet:https://doc.telink-semi.cn/doc/d ... LE_SoC_TLSR8208.pdf
 楼主| 发表于 2026-1-23 22:43:00 | 显示全部楼层 来自 中国
There is also no programmer supporting this chip:https://doc.telink-semi.cn/doc/e ... ugging-tool-windows
