查看: 1005|回复: 2
[BLE SDK] How to scan BLE Long Range devices on the TLSR9511B?
发表于 2026-1-13 13:23:00 | 显示全部楼层 |阅读模式 来自 俄罗斯
芯片型号: TLSR9511B
SDK及版本: telink_b91m_btble_dual_mode_general_sdk-5.3.0.0_Patch_0003
How to scan BLE Long Range (S2/S8 coding modes)  devices on the TLSR9511B?
The file telink_b91m_btble_dual_mode_general_sdk_Release_Note.md says to uncomment the call blc_ll_init2MPhyCodedPhy_feature.
I did this, but the BLE Long Range (S2/S8 coding modes) devices are still not scanned, only the BLE device 1M are scanned.
 楼主| 发表于 2026-2-4 19:49:59 | 显示全部楼层 来自 俄罗斯
Topic is relevant.
Someone was scanning BLE Long Range (S2/S8 coding modes)  devices on the TLSR9511B?
发表于 2026-8-13 10:52:12 | 显示全部楼层 来自 上海
Hello,
To capture advertisements from peripherals working under BLE Long Range (S2/S8 coded PHY), the scanning device must support the extended scan feature.
The current SDK version telink_b91m_btble_dual_mode_general_sdk-5.3.0.0_Patch_0003 only implements legacy scanning, and this long-range coded device scanning function is not available for now.
If this capability is mandatory for your project, please reach out to our global sales representatives or FAEs for customized solution evaluation. All regional contact information is available on our official page:  https://www.telink-semi.com/
