查看: 1351|回复: 4
[BTBLE IOT] B91 BT/Low Latency Concurrent General SDK location
发表于 2026-1-6 06:33:07 | 显示全部楼层 |阅读模式
I wanted to know if the SDK at https://doc.telink-semi.cn/doc/e ... btll_concurrent_en/ was available for download. I cannot find the repository anywhere
发表于 2026-1-9 20:07:39 | 显示全部楼层
you can download it here https://github.com/telink-semi
 楼主| 发表于 2026-1-14 04:30:12 | 显示全部楼层
Hello, thank you for the response. Which repository is it? None of them seem to match
发表于 2026-1-28 11:48:24 | 显示全部楼层
Sorry, I made a mistake. We have not publicly released this SDK. If you need to obtain it, please contact our sales department or evaluate whether other SDKs can meet your needs
发表于 2026-8-14 09:53:43 | 显示全部楼层
The B91 BT/Low Latency Concurrent General SDK is no longer maintained and was never publicly released. Our current available SDK is the Bluetooth Audio SDK, which can be obtained at: https://www.telink-semi.com/products/bluetooth-classic/tl751x. The corresponding handbook will be released at the end of August 2026 via this link: https://doc.telink-semi.cn/doc/e ... sdk_Get_Started_en/
