查看: 1319|回复: 3
[BLE SDK] PWM RGB in BLE SUSPEND MODE
发表于 2025-12-23 20:11:56 | 显示全部楼层 |阅读模式 来自 广东
芯片型号: 8208
SDK及版本: b80_ble_sdk
During the BLE mode, when suspend is enabled, the PWM (RGB Light) is effected as well which i guess due to the clock frquency is gated. Does this mean when using the PWM function, the BLE Suspend mode must be disabled? Or is there a different way to handle this issue
发表于 2025-12-24 11:29:57 | 显示全部楼层 来自 上海
During suspend mode, some registers will be powered down which will effect the PWM function. so that you need to disable the suspend mode when using the PWM function
Thanks
 楼主| 发表于 2025-12-24 15:49:36 | 显示全部楼层 来自 广东
Thank you for the reply
发表于 2026-1-6 13:56:17 | 显示全部楼层 来自 上海
