查看: 3987|回复: 0
[reprinted]ZigBee SDK - debugging End Device
发表于 2024-8-22 19:56:13 | 显示全部楼层 |阅读模式 来自 上海
[Transferred from old forum] Author: wes58
I have a device (TLSR8258) which is an End Device with PM enabled (#define PM_ENABLE1)
Is it possible to debug this device with BDT?
When I try to do it I get:
- when clicking on "Pause" button in BDT I get
pause mcu, pc : 0x000002
- when clicking on "PC"button I get
pc : 0x000000
- when I try to read variables I get
[88]: read memory err!
This is obviously because when I click on the button, the device is in sleep mode.
I there a way to debug such a device?
I also tried to disable PM (#define PM_ENABLE 0), clean the project, re-build and flash the device but the device still behaves like it is with PM enabled - I get the same results when pausing, reading variables as described above.
I don't want to erase the device which would probably fix it, but then I would have to pair it with the gateway again.
I would like to avoid it.
Why would this be happening?
I found the reason why I couldn't debug the device and I thought that the device was still in sleep mode after I disabled PM.
The reason was that I had configured the SWS pin as GPIO input which disabled SWS.
