查看: 2449|回复: 1
otbr设置thread网络失败
发表于 2025-4-20 19:55:26 | 显示全部楼层 |阅读模式 来自 上海
硬件:树莓派4B搭载ubuntu server24.04LTS+nrf52840dongle作为otbr
问题:在设置thread网络时出现"Param:'dataset init new' connect session failed: No such file or directory"
命令:./certification-tool/backend/test_collections/matter/scripts/OTBR/otbr_start.sh
打印:ubuntu@ubuntu:~$ ./certification-tool/backend/test_collections/matter/scripts/OTBR/otbr_start.sh
otbr_start.sh: Starting...
otbr_start.sh: Removing 'otbr-chip' container
nrfconnect/otbr                                        9185bda                                    083c8472bc52   23 months ago   1.21GB
otbr image nrfconnect/otbr:9185bda already installed
otbr_start.sh: Starting 'otbr-chip' container
5886f571195a009e2e27560f0baccb42698aafd025118c249f4ab6ad2a9d60d5
otbr_start.sh: Waiting 10 seconds to give the the docker container enough time to start up...
otbr_start.sh: Setting up Thread Network
Param: 'dataset init new'connect session failed: No such file or directory
如果我直接运行sudo ot-ctl dataset active -x就会显示sudo: ot-ctl: command not found
12
发表于 2025-4-21 11:40:50 | 显示全部楼层 来自 上海
这个报错的原因是RCP没有正确识别,如果确认RCP固件正确,再重新插拔dongle,重启树莓派再进行尝试。
