查看: 5561|回复: 16
Temperature Measurement Client如何接收已绑定的server数据呢
流光翡翠
发表于 2025-4-14 19:40:27 | 显示全部楼层 |阅读模式 来自 广东深圳
SDK及版本: V3.7.1.2_Patch_0001(PR)
请问Temperature Measurement Client已和Temperature Measurement Server进行了绑定,那么server report温度后,在client如何收到report过来的温度呢?
22
超凡大师
发表于 2025-4-16 10:30:50 | 显示全部楼层 来自 澳大利亚
If I understand you correctly you want another device that is bound to the Temp. Measurement Server to receive temperature.
In zcl_XXXCb.c  there is function App_zclReportCmd(zclReportCmd_t *pReportCmd)
XXX is you project name.
* @fn      App_zclReportCmd
* @brief   Handler for ZCL Report command.
* @param   pInHdlrMsg - incoming message to process
* @return  None
//static void App_zclReportCmd(zclReportCmd_t *pReportCmd){
By the way, I changed it to zcl_appCb.c so I don't have to change it when I copy the code to a new project
You have to write the code to read the data.
For example I have the following code to read the onOff status that I receive from another device.
        zclReportCmd_t *pReportCmd = (zclReportCmd_t *)pInMsg->attrCmd;
                for(u8 i = 0; i < pReportCmd->numAttr; i++){
                        u8 dataType = pReportCmd->attrList.dataType;
                        if(dataType == ZCL_DATA_TYPE_UINT8){        // ZCL_DATA_TYPE_BOOLEAN){
                                u8 *state = pReportCmd->attrList.attrData;
                                u8 status = *state;
                                if(status == 0){
                                        led_off(LED_GARAGE);
                                else{
                                        led_on(LED_GARAGE);
26
流光翡翠
 楼主| 发表于 2025-4-24 08:18:40 | 显示全部楼层 来自 广东深圳
明白了,谢谢!
流光翡翠
发表于 2025-5-6 03:37:56 | 显示全部楼层 来自 俄罗斯
Hi.
How can I determine the bind and unbind of an external temperature sensor?
22
超凡大师
发表于 2025-5-6 14:37:29 | 显示全部楼层 来自 澳大利亚
Slacky 发表于 2025-5-6 03:37
Hi.
This is probably translation from Chinese that it doesn't make it clear. So I will write this.
If you want to bind/unbind device you can use ZGC Tool.
Another method (that I use) you can send a ZBHCI message to the gateway (coordinator) like this:
ZBHCI message BIND
550020A4C1385DF0632B3C1B000603A4C138E000329CC601
where:
cmd 550020
Binding device IEEE addr A4C1385DF0632B3C
ep 1B
binding cluster 0006
mode IEEE addr 03
Bind to Device IEEE addr A4C138E000329CC6
ep 01
ZBHCI message UNBIND
550021A4C1385DF0632B3C1B000603A4C138E000329CC601
where:
cmd 550021
A4C1385DF0632B3C
1B
0006
03
A4C138E000329CC6
01
If you want to check what devices are bound to your temperature sensor you can send ZBHCI command to read the binding table of the device.
Check binding table
550031BF8F00
where:
cmd 550031
Ntw. address of the device BF8F
starting index 00
26
流光翡翠
 楼主| 发表于 2025-5-7 17:46:40 | 显示全部楼层 来自 广东深圳
如何确认绑定成功了呢? 绑定成功后,应用层有callback提示吗?
22
超凡大师
发表于 2025-5-8 05:26:33 | 显示全部楼层 来自 澳大利亚
You should receive ZBHCI message like this:
55 80 20 00 04 94 16 22 04 00 aa
Byte 9 is the status - 00 - binding success
You can check zbhci.h file and you will find: ZBHCI_CMD_BINDING_RSP = 0x8020
And when you look for it in zbhciCmdProcess.c you will find function  zbhciBindRspPush(void* arg)
26
流光翡翠
 楼主| 发表于 2025-5-9 18:29:17 | 显示全部楼层 来自 广东深圳
我指的比如sensor应用,和其它设备绑定成功后,有没有callback到应用层。而不是指gateway.
发表于 2025-5-9 19:05:06 | 显示全部楼层 来自 上海
Rory 发表于 2025-5-9 18:29
我指的比如sensor应用,和其它设备绑定成功后,有没有callback到应用层。而不是指gateway. ...
绑定处理暂未开放,但可以直接遍历绑定表来检查。
  1. /* binding table */
  2. u8 APS_BINDING_TABLE_SIZE = APS_BINDING_TABLE_NUM;
  3. aps_binding_entry_t g_apsBindingTbl[APS_BINDING_TABLE_NUM];
复制代码
流光翡翠
发表于 2025-5-10 17:47:29 | 显示全部楼层 来自 俄罗斯
But this table does not have records about external sensor, it only has internal ones. And the destination address is the address of the coordinator.
bound
  1. app_zclReportCmd
  2. bind_tbl
  3. addr_mode: 0x03, clId: 0x040D, addr: 0xF8:0x17:0xD5:0x30:0x00:0x4B:0x12:0x00:
  4. bind_tbl
  5. addr_mode: 0x03, clId: 0x0402, addr: 0xF8:0x17:0xD5:0x30:0x00:0x4B:0x12:0x00:
  6. bind_tbl
  7. addr_mode: 0x03, clId: 0x0405, addr: 0xF8:0x17:0xD5:0x30:0x00:0x4B:0x12:0x00:
  8. bind_tbl
  9. addr_mode: 0x03, clId: 0x0400, addr: 0xF8:0x17:0xD5:0x30:0x00:0x4B:0x12:0x00:
  10. bind_tbl
  11. addr_mode: 0x03, clId: 0x0403, addr: 0xF8:0x17:0xD5:0x30:0x00:0x4B:0x12:0x00:
复制代码
unbound
  1. app_zclCfgReportCmd
  2. bind_tbl
  4. bind_tbl
  6. bind_tbl
  8. bind_tbl
  10. bind_tbl
复制代码
