查看: 3506|回复: 1
[PM] pm_tim_recover_32k_rc() 貌似无效
发表于 2025-4-5 20:43:27 | 显示全部楼层 |阅读模式 来自 四川
芯片型号: TSLR8258
驱动SDK版本: tc_ble_sdk-V4.0.2.0
系统设计流程:上电---> 运行应用逻辑 --->(A)读取clock_time()  和 32k RC counter ---> 进入deep sleep (no retention) ---> 通过gpio/timer wakeup 唤醒 ---> (B) 唤醒后 读取clock_time()  和 32k RC counter
系统PM配置:  PM_TIM_RECOVER_MODE 设置为1,     PM_LONG_SLEEP_WAKEUP_EN 设置为1, BLE_APP_PM_ENABLE配置为1,  配置的是internal 32k
发现现象: 在B点所读取的clock_time() 及system tick 值,并未做recover恢复。
                 A点:clock time =208936     32k RC counter = 870
                 B点:clock time =209728    32k RC counter = 2014583
这说明 PM_TIM_RECOVER_MODE 并未生效。
若 在A之前 加上代码 pm_tim_recover_32k_rc(pm_get_32k_tick());   实际结果和上面描述一样。 想了解  deepsleep后,通过 internal 32K RC counter 补偿恢复 system  tick的有效方法。
发表于 2025-7-11 17:02:24 | 显示全部楼层 来自 上海
我们初始化有接口可以实现,static inline void blc_pm_select_internal_32k_crystal(void)
        cpu_sleep_wakeup                  = cpu_sleep_wakeup_32k_rc;
        pm_tim_recover                   = pm_tim_recover_32k_rc;
        blt_miscParam.pm_enter_en         = 1; // allow enter pm, 32k rc does not need to wait for 32k clk to be stable
_attribute_ram_code_sec_noinline_ unsigned int pm_tim_recover_32k_rc(unsigned int now_tick_32k)
        unsigned int deepRet_tick;
#if (PM_TIM_RECOVER_MODE)
        if(pm_timRecover.recover_flag == 0x03){
                deepRet_tick = pm_timRecover.tick_sysClk + (unsigned int)(now_tick_32k - pm_timRecover.tick_32k) * tick_32k_calib / 16;                // current clock
        else
#endif
#if PM_LONG_SUSPEND_EN  //do not consider  deepsleep retention  timer wake_up(bigger than 16S)
                if(pm_long_suspend){
                        deepRet_tick = tick_cur + (unsigned int)(now_tick_32k - tick_32k_cur) / 16 * tick_32k_calib;
                else{
                        deepRet_tick = tick_cur + (unsigned int)(now_tick_32k - tick_32k_cur) * tick_32k_calib / 16;                // current clock
#else
#endif
        return deepRet_tick;
