查看: 2740|回复: 2
zigbee sdk 3.6.7有没有接口获取rssi值
发表于 2025-3-19 17:01:52 | 显示全部楼层 |阅读模式 来自 中国
SDK及版本: zigbee v3.6.7
8258 zigbee sdk 3.6.7有没有接口获取rssi值
发表于 2025-3-21 17:18:11 | 显示全部楼层 来自 上海
  1. s8 rssi = ZB_RADIO_RSSI_GET();
复制代码
发表于 2025-4-5 19:32:43 | 显示全部楼层 来自 俄罗斯
Hi.
The function is called every 10 seconds. Different modules from E-Byte and Tuya ZTU were checked. The result never rises above -90 dB. Although z2m shows 116 lqi, which can't correspond to -90 dB.
  1. ZB_RADIO_RSSI_GET: -110
  2. ZB_RADIO_RSSI_GET: -97
  3. ZB_RADIO_RSSI_GET: -100
  4. ZB_RADIO_RSSI_GET: -97
  5. ZB_RADIO_RSSI_GET: -105
  6. ZB_RADIO_RSSI_GET: -97
  7. ZB_RADIO_RSSI_GET: -106
  8. ZB_RADIO_RSSI_GET: -105
  9. ZB_RADIO_RSSI_GET: -106
  10. ZB_RADIO_RSSI_GET: -100
  11. ZB_RADIO_RSSI_GET: -106
  12. ZB_RADIO_RSSI_GET: -100
  13. ZB_RADIO_RSSI_GET: -103
复制代码
