查看: 3556|回复: 1
[BLE SDK] Erase while BLE is connected
流光翡翠
发表于 2025-3-12 08:15:39 | 显示全部楼层 |阅读模式 来自 德国
芯片型号: TLSR8251
SDK及版本: b85m_ble_single_connection_sdk_V3.4.2.4 patch_3
Hello,
the documentation at https://doc.telink-semi.cn/doc/e ... onnection_en/#flash mentions that "For BLE slave applications, if the unavoidable flash_erase_sector occurs occasionally, you can use the Conn state Slave role timing protection mechanism to avoid it. Please refer to the details of this document.".
Unfortunately I need to use flash_erase_sector occasionally and I tried to find that document to find out what I need to do but I was unable to find it. Could you please link to it or explain how to properly use flash_erase_sector while staying connected over BLE?
Thanks!
发表于 2025-3-17 09:45:21 | 显示全部楼层 来自 上海
Please refer to 3.2.4.7 Timing Protect for Conn State Slave role in https://wiki.telink-semi.cn/doc/ ... oper%20Handbook.pdf
