查看: 5864|回复: 2
How to check that sampleLight is commissioned ?
璀璨钻石
发表于 2025-2-20 16:08:51 | 显示全部楼层 |阅读模式 来自 韩国
SDK及版本: telink_zigbee_ble_concurrent_sdk-2.4.0.0
When sampleLight is commissioned, zb_getMacAssocPermit() is changed from 0 to 1.
But if sampleLight is rebooted, zb_getMacAssocPermit() is not changed to 1.
33
璀璨钻石
 楼主| 发表于 2025-2-20 21:31:34 | 显示全部楼层 来自 韩国
zb_isDeviceJoinedNwk() is OK
29
发表于 2025-2-24 09:34:08 | 显示全部楼层 来自 上海
After successfully join the network, you can press the button SW2 to allow or disable the permit join state.
