查看: 6361|回复: 1
[BLE SDK] about security connection methods
发表于 2025-2-19 13:09:39 | 显示全部楼层 |阅读模式 来自 韩国
SDK及版本: 825x_BLE_SDK
Hello.
I have a slave module and a smartphone as the master,
and I want to use a password key for pairing and bonding.
I am asking if setting the parameter to "Authenticated_Paring_with_Encryption" in the following API function is enough:
blc_smp_setSecurityLevel(Authenticated_Paring_with_Encryption);
发表于 2025-3-11 14:56:41 | 显示全部楼层 来自 上海
Sorry, we missed this question. I hope it's not too late.
Could you tell me the details of the SDK you used? I will show you the demos that you can follow depending on the SDK you are using.
