查看: 6531|回复: 5
Watchdog
发表于 2025-2-4 23:54:53 | 显示全部楼层 |阅读模式 来自 俄罗斯
芯片型号: TLSR8258F1
SDK及版本: V3.7.1.2(PR)
Hello.
How to find where the program freezes and reboot from watchdog?
Thanks.
 楼主| 发表于 2025-2-13 00:25:37 | 显示全部楼层 来自 俄罗斯
No solution?
发表于 2025-2-14 13:48:34 | 显示全部楼层 来自 上海
You can use register DEEP_ANA_REG10 to implement it.
The description of registers can refer to the pm.h header file.
  1. /**
  2. * @brief these analog register can store data in deepsleep mode or deepsleep with SRAM retention mode.
  3. *               Reset these analog registers by watchdog, chip reset, RESET Pin, power cycle
  4. */
  5. #define DEEP_ANA_REG6                       0x35 //initial value =0x20
  6. #define DEEP_ANA_REG7                       0x36 //initial value =0x00
  7. #define DEEP_ANA_REG8                       0x37 //initial value =0x00
  8. #define DEEP_ANA_REG9                       0x38 //initial value =0x00
  9. #define DEEP_ANA_REG10                      0x39 //initial value =0xff
复制代码
 楼主| 发表于 2025-2-15 03:24:24 | 显示全部楼层 来自 俄罗斯
Hello.
How does this help us understand where the program crashed?
发表于 2025-2-18 10:58:02 | 显示全部楼层 来自 上海
For example, when your system is running normally, you can write a value to register DEEP_ANA_REG10.
  1. analog_write(DEEP_ANA_REG10, VALUE)
复制代码
When the system restarts, check if the expected value written in register DEEP_ANA_REG10 is correct.
If not, it indicates that the watchdog restart has been triggered.
 楼主| 发表于 2025-3-15 23:12:50 | 显示全部楼层 来自 俄罗斯
Hello.
Doesn't work without PM?
I write 0x65 to the register, but after reboot it always returns 0xFF.
