查看: 4271|回复: 2
Sometimes zb_factoryReset(); is not worked.
璀璨钻石
发表于 2025-2-4 08:54:11 | 显示全部楼层 |阅读模式 来自 韩国
SDK及版本: telink_zigbee_ble_concurrent_sdk-2.4.0.0
I comission TLSR8258 Dongles with telink_zigbee_ble_concurrent_sdk-2.4.0.0.
Each dongle have 3 endpoints(light, motion sensor, daylight sensor).
I run factory reset after 1 ~3 days.
some dongles not run zb_factoryReset().
Can you check it ?
29
发表于 2025-2-5 10:31:02 | 显示全部楼层 来自 上海
After calling zb_factoryReset(), the stack will start a factory new task (to send leave),
then nv_resetToFactoryNew() will be called to erase flash data,
and finally call back to sampleXX_leaveCnfHandler().
33
璀璨钻石
 楼主| 发表于 2025-2-6 07:29:10 | 显示全部楼层 来自 韩国
then nv_r ...
void factoryRst_handler(void){
        if(factoryRst_exist){
//#if (DEBUG_MODE == 1)
                printf("===================start factory reset2=========\r\n");
//#endif
                factoryRst_exist = FALSE;
                zb_factoryReset();
void sampleLight_leaveCnfHandler(nlme_leave_cnf_t *pLeaveCnf)
                printf("===================sampleLight_leaveCnfHandler====%d=====\r\n", pLeaveCnf->status);
//#endif
    if(pLeaveCnf->status == SUCCESS)
            light_blink_start(3, 200, 200);
            //waiting blink over
        TL_ZB_TIMER_SCHEDULE(sampleLight_recoveryStart, NULL, 2 * 1000);
===================start factory reset2=========<CR><LF>
===================sampleLight?leaveCnfHandler====194=====<CR><LF>
pLeaveCnf->status is 194 in sampleLight_leaveCnfHandler()
sometimes sampleLight_leaveCnfHandler() is not worked.
What is problem ?
