查看: 5871|回复: 3
How to copy commission data between each Coordinator Sticks(sampleGW) ?
璀璨钻石
发表于 2025-1-17 16:47:29 | 显示全部楼层 |阅读模式 来自 韩国
芯片型号: tlsr8258
SDK及版本: telink_zigbee_ble_concurrent_sdk-2.4.0.0
When I use 40pcs sampleLights and 2pcs sampleGw.
1. I commission 40pcs sampleLight with 1st sampleGw.
2. and I exchanged 1st sampleGw to 2nd sampleGw.
3. and I can not communicate 2nd sampleGw and 40pcs sampleLights.
How to communicate 2nd sampleGw and 40pcs sampleLight ?
29
发表于 2025-2-5 10:13:02 | 显示全部楼层 来自 上海
A zigbee network(PAN) can only have one coordinator.
Two coordinators are two different PANs and cannot communicate directly with each other.
33
璀璨钻石
 楼主| 发表于 2025-2-5 12:55:47 | 显示全部楼层 来自 韩国
Two coordinators are two different PANs and can ...
I mean that I want to copy network information from original coordinator to other coordinator for backup.
I want to use other coordinator when I lost original coordinator.
29
发表于 2025-2-5 14:01:57 | 显示全部楼层 来自 上海
jylee@kme21.com 发表于 2025-2-5 12:55
I mean that I want to copy network information from original coordinator to other coordinator for  ...
Sorry~
The easy way is to copy the NV data from 1st to 2nd GW. (All NV data info are defined in drv_nv.h)
The premise is that you can read NV data from 1st or have already backed up the NV data to the cloud.
