查看: 3814|回复: 7
How to adjust period of "Route Request" command of sampleLight ?
璀璨钻石
发表于 2024-12-30 19:04:36 | 显示全部楼层 |阅读模式 来自 韩国
SDK及版本: zigbee_ble_concurrent_sdk_v2.4.0.0
How to adjust period of "Route Request" (NWK_CMD_ROUTE_REQUEST) command of sampleLight ?
How to send "Route Request" command  (NWK_CMD_ROUTE_REQUEST) periodic on sampleLight ?
29
发表于 2024-12-31 20:23:07 | 显示全部楼层 来自 上海
When the protocol stack network layer receives data from the upper layer, it will check the destination address and decides whether to send AODV routing requests.
Are you referring to periodic broadcast sending MTO requests?
33
璀璨钻石
 楼主| 发表于 2025-1-2 07:23:03 | 显示全部楼层 来自 韩国
TL_YB 发表于 2024-12-31 20:23
When the protocol stack network layer receives data from the upper layer, it will check the destinat ...
yes. i want periodic.
and I want to adjust the periodic times when a coordinator is connected and disconnected.
29
发表于 2025-1-2 19:51:22 | 显示全部楼层 来自 上海
You can adjust the MTO periodic time of the Coordinator by following these steps,
1. set NWK_NIB().concentratorDiscoveryTime to the new value as needed, the unit is seconds.
2. call the zb_routeDiscReq() function to restart the MTO periodic timer.
  1. nlme_routeDisc_req_t req;
  2. req.dstAddrMode = ZB_ADDR_NO_ADDR;
  3. req.dstAddr = 0xFFFC;
  4. req.radius = NWK_NIB().concentratorRadius;
  5. req.noRouteCache = NWK_ROUTE_RECORD_TABLE_SIZE ? FALSE : TRUE;
  6. zb_routeDiscReq(&req);
复制代码
33
璀璨钻石
 楼主| 发表于 2025-1-3 07:13:55 | 显示全部楼层 来自 韩国
1. set NWK_NIB().c ...
Is there any way to send "Route Request" command (NWK_CMD_ROUTE_REQUEST) from sampleLight?
29
发表于 2025-1-3 09:37:33 | 显示全部楼层 来自 上海
simpleLight does not support MTO, and a destination address must be specified.
  2. req.dstAddrMode = ZB_ADDR_16BIT_DEV_OR_BROADCAST;
  3. req.dstAddr = 0x0000;//coordinator
  4. req.radius = 0;
  5. req.noRouteCache = 1;
复制代码
33
璀璨钻石
 楼主| 发表于 2025-1-8 10:03:05 | 显示全部楼层 来自 韩国
It is not effected.
Currently, sampleLight send "Route Request" every 1minutes(60 seconds) when coordinator is detected.
Can I change this time to every 10 seconds when coordinator is connected and not connected ?
29
发表于 2025-1-8 15:08:35 | 显示全部楼层 来自 上海
The sampleLight does not support periodic MTO routing,
you can create a timer task to send AODV routing requests.
