查看: 5583|回复: 1
[BLE Mesh] How to add vendor command ?
璀璨钻石
发表于 2024-12-5 07:37:33 | 显示全部楼层 |阅读模式 来自 韩国
芯片型号: B85
SDK及版本: 4.1.0.1
I add vendor command in SigMesh SDK v4.1.0.1.
But I get below messages.
model 0x0211 did't bind this key in element index 0
How to fix it ?
发表于 2024-12-5 14:21:49 | 显示全部楼层 来自 广东深圳
After adding the vendor OP, it is necessary to re network the nodes to bind keys to all OPs; It is possible that the newly added vendor op did not have a bind key, which led to whether the vendor model was bound with a key before adding the vendor op? Will adding only one vendor opcode in the Telink demo cause this problem without changing any other code?
