查看: 2863|回复: 3
zigbee 门锁品类
发表于 2024-12-3 10:38:56 | 显示全部楼层 |阅读模式 来自 广东广州
请问8258 zigbee 有门锁相关的demo实现例程吗
22
发表于 2024-12-4 13:15:23 | 显示全部楼层 来自 澳大利亚
From my experience I would say you have to do it yourself. I had to do it for other devices that I had to add.
It shouldn't be too hard because you will find all the information in zigbee\zcl\closures\ folder.
You can compare any other example and add what you need for your door lock.
 楼主| 发表于 2024-12-5 10:02:18 | 显示全部楼层 来自 广东广州
I see, thanks
