查看: 4432|回复: 5
[BLE Mesh] how to reduce power
流光翡翠
发表于 2024-11-29 22:25:40 | 显示全部楼层 |阅读模式 来自 印度
芯片型号: enable suspend mask
after lpn provision ok ENABLE_SUSPEND _MASK what sleep they are configuring bls_pm_setSuspendMask(SUSPEND_ADV | DEEPSLEEP_RETENTION_ADV | SUSPEND_CONN | DEEPSLEEP_RETENTION_CONN)
here still its consuming 400uA how to reduce
发表于 2024-12-2 14:55:20 | 显示全部楼层 来自 广东深圳
LPN can reduce the power consumption before establishing a connection with friend by increasing FRI-REQ_TIMEOUT_SS (default is 2s); If you want to reduce the power consumption after establishing a connection with your friend, you can increase FRI-POLLINTERVAL_S (default is 2s)
29
流光翡翠
 楼主| 发表于 2024-12-2 18:25:41 | 显示全部楼层 来自 印度
TL_HSF 发表于 2024-12-2 14:55
LPN can reduce the power consumption before establishing a connection with friend by increasing FRI ...
while increasing FRI_POLL_INTERVAL_MS current consumption also be 700UA,i have configured FRI_POLL_INTERVAL_MS for 120 seconds while sleep its consuming 700 UA how to reduce?
发表于 2024-12-3 16:04:02 | 显示全部楼层 来自 广东深圳
Test the dongle and demo of Telink, without making any changes, to see if the measured power consumption meets expectations;
发表于 2024-12-3 16:04:39 | 显示全部楼层 来自 广东深圳
The average power consumption for a poll and update should be over 60 UA; Exclude whether it is a hardware issue
