查看: 3407|回复: 3
I2C怎么用
发表于 2024-11-27 09:51:26 | 显示全部楼层 |阅读模式 来自 湖南
drv_i2c_write_series(I2C_SLAVE_ID, I2C_SLAVE_ADDR, I2C_SLAVE_ADDR_LEN, tx_data, 1);
        WaitMs(10);  // 等待测量完成
        drv_i2c_read_series(I2C_SLAVE_ID, I2C_SLAVE_ADDR, I2C_SLAVE_ADDR_LEN,data,6);
关于这两个函数 里面的各个参数是什么呢,特别是这个I2C_SLAVE_ID,它支持挂多少设备嘛?
22
发表于 2024-11-27 11:47:08 | 显示全部楼层 来自 澳大利亚
As you know, you can have multiple devices on the I2C bus. So how would you identify the device that you want to read/write data to? That's why you need to define I2C_SLAVE_ID. You will find it in your device datasheet. The same with I2C_SLAVE_ADDR - what address are you going to write data to? Or read data from? You decide that - again looking in your device datasheet.
Hope that it helps.
22
 楼主| 发表于 2024-11-27 11:52:10 | 显示全部楼层 来自 湖南
wes58 发表于 2024-11-27 11:47
As you know, you can have multiple devices on the I2C bus. So how would you identify the device that ...
hi,
Thank you,I've already solved the problem
