查看: 4517|回复: 2
SDK 3.7.1.1 (and 3.7.1.0 too) raises exception with event 21 in reportNoMinLimit
发表于 2024-11-23 20:43:50 | 显示全部楼层 |阅读模式 来自 俄罗斯
Hello.
void report_handler(void)
    if(zb_isDeviceJoinedNwk()){
        if(zcl_reportingEntryActiveNumGet()){
            uint16_t second = 1;//TODO: fix me
            reportNoMinLimit();
            //start report timer
            reportAttrTimerStart(second);
        }else{
            //stop report timer
            reportAttrTimerStop();
void app_task(void) {
    uart_cmd_handler();
    if(bdb_isIdle()) {
        report_handler();
My log
OTA mode enabled. MCU boot from address: 0x8000
out_pkt <== 0x55AA02000101000003
inp_pkt ==> 0x55AA02000101001C7B2270223A227539626677686130222C2276223A22342E302E31227D84
manuf_name: 0, u9bfwha0 is find
out_pkt <== 0x55AA0200020200010107
inp_pkt ==> 0x55AA02000202000005
app_sysException, line: 198, event: 21, reset
If commented reportNoMinLimit()
//            reportNoMinLimit();
        }else{
            //stop report timer
    uart_cmd_handler();
    if(bdb_isIdle()) {
        report_handler();
It's Ok.
inp_pkt ==> 0x55AA020003060005240400010139
command 0x06
out_pkt <== 0x55AA020003060001010C
command 0x06
command 0x06
command 0x06
command 0x06
SDK 3.6.8.7 works great!!!
发表于 2024-11-25 15:58:35 | 显示全部楼层 来自 上海
It seems that reportNoMinLimit() caused queue overflow due to frequent creation of sending tasks.
Can you provide your reportingTab information?
