查看: 6320|回复: 1
[BLE SDK] How to avoid reset from wakeup deepslepp mode
流光翡翠
发表于 2024-11-22 12:40:01 | 显示全部楼层 |阅读模式 来自 印度
IN TLSR8258 low power node example i have configured one button, in that  button for short press i am sending generic on off command and in long press do factory reset but the problem is while short press it's sending the generic command as well as it is doing reset how to avoid reset while short press(i am putting device in deep sleep mode when button is not pressed)
while wakeup from deep sleep mode will reset occur and how to solve ?
发表于 2024-11-25 19:11:29 | 显示全部楼层 来自 上海
It is normal for IC to reset when it wakes up from deep sleep mode.This is the design of the IC.
