查看: 7400|回复: 4
matter commissioning 失败
发表于 2024-11-5 14:49:13 | 显示全部楼层 |阅读模式 来自 上海嘉定区
您好,我拉取了matter的最新master分支代码,使用了lock-app 例子测试matter 功耗情况, 在配网阶段失败了,可以帮忙分析一下原因吗, 同时提供一下这个tlsr9528a芯片的数据手册链接吗,在官网没有找到. 另外还有个疑问如果在挂起模式总的RAM超过96KB是不是就代表深度睡眠模式不可以使用了?,谢谢
west build -b tlsr9528a_retention
[670/671] Linking CXX executable zephyr/zephyr.elf
Memory region         Used Size  Region Size  %age Used
       RAM_ILM_N:       53466 B       160 KB     32.63%
         RAM_DLM:       36244 B       256 KB     13.83%
             ROM:      879336 B         2 MB     41.93%
             RAM:       89044 B        96 KB     90.58%
        IDT_LIST:          0 GB         2 KB      0.00%
I: 253124 [ZCL]Cluster callback: 0x0000_0030
I: 253134 [EM]<<< [E:35896r S:50162 M:196728514] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [8622] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 253150 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 253466 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 253477 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 253490 [EM]>>> [E:35897r S:50162 M:256094908] (S) Msg RX from 1:FFFFFFFB00000000 [8622] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
I: 253508 [FS]GeneralCommissioning: Received ArmFailSafe (108s)
I: 253516 [ZCL]Cluster callback: 0x0000_0030
I: 253526 [EM]<<< [E:35897r S:50162 M:196728515] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [8622] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
D: 253542 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 253736 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 253747 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 253760 [EM]>>> [E:35898r S:50162 M:256094909] (S) Msg RX from 1:FFFFFFFB00000000 [8622] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:73)
I: 253801 [ZCL]Cluster callback: 0x0000_0030
I: 253811 [EM]<<< [E:35898r S:50162 M:196728516] (S) Msg TX from 0000000000000000 to 1:FFFFFFFB00000000 [8622] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:65)
D: 253827 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 253836 [DL]HandleThreadStateChange
D: 253840 [DL]OpenThread State Changed (Flags: 0x10000000)
D: 253847 [DL]HandleOperationalNetworkEnabled
D: 253854 [DL]Using Thread extended MAC for hostname.
I: 253859 [DIS]Advertise operational node A9BB0A90D5F28622-00000000E85A9056
E: 253867 [SVR]Operational advertising failed: 3
D: 254366 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x0e)
I: 254375 [DL]BLE GAP connection terminated (reason 0x16)
D: 254381 [IN]Clearing BLE pending packets.
I: 254385 [DL]Current number of connections: 0/1
I: 254390 [DL]Switch context from BLE to Thread
D: 254405 [DL]HandleThreadStateChange
D: 254409 [DL]OpenThread State Changed (Flags: 0x1100101d)
D: 254415 [DL]   Device Role: DETACHED
D: 254419 [DL]   Thread Unicast Addresses:
D: 254423 [DL]        fdb7:4c29:3275:be81:974a:6907:ce97:709/64 valid
D: 254430 [DL]        fe80::a494:e881:bca7:9314/64 valid preferred
E:
E:  mcause: 2, Illegal instruction
E:   mtval: befc
E:      a0: 0000004b    t0: 00000027
E:      a1: 00000000    t1: 0000000d
E:      a2: 00000001    t2: 00000000
E:      a3: c0aa1200    t3: 00001b2c
E:      a4: 00000000    t4: 00000001
E:      a5: 00000005    t5: 0000000d
E:      a6: 0e4e1c00    t6: 0000000f
E:      a7: 0000000c
E:      ra: 20040446
E:    mepc: 00018db8
E: mstatus: 00001880
E:
E: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
E: Current thread: 0xb3a8 (openthread)
E: Halting system
!!! system halt reason 0
!!! reboot
 楼主| 发表于 2024-11-5 18:42:06 | 显示全部楼层 来自 上海嘉定区
有没有一个BLE 例子支持zephyr tlsr9528a_retention 编译的?
 楼主| 发表于 2024-11-7 09:33:12 | 显示全部楼层 来自 上海嘉定区
可以回复一下吗?
发表于 2024-11-8 09:36:19 | 显示全部楼层 来自 广东惠州
Same problem:
"Enable Power Management" commission Failed
发表于 2024-11-11 10:09:31 | 显示全部楼层 来自 上海
最新的master分支中,有关retention部分我们正在修复,如果你需要尝试的话,可以换一个commit
具体的commit如下:
Codebase Foundation:
– Zephyr repository: https://github.com/telink-semi/zephyr/tree/develop
        Commit ID: e0800ce0375563dfeea8ffc32ebc78d5aaf4f091
– Matter repository: https://github.com/project-chip/connectedhomeip/tree/master
        Commit ID: 1536ca20c5917578ca40ce509400e97b52751788
Datasheet:
DS-TLSR9528-E9_Datasheet for Telink Multi-Standard Wireless SoC TLSR9528.pdf
5.18 MB, 下载次数: 5
