查看: 5997|回复: 1
[BLE Mesh] Port our code to a different Chipset
发表于 2024-10-28 13:43:44 | 显示全部楼层 |阅读模式 来自 四川
芯片型号: TLSR 8258
SDK及版本: sig_mesh_sdk
  We want to port our code to a different Chipset (TLSR 8250 or 8253) 32 Pin from TLSR 8258 .
  We have made changes in the SDK so the BLE Part is functioning good (Onboarding and Controls are happening ) , but we cannot see any output on our changed GPIOs . Even Logs are not coming on our intended GPIO .
  Please help to share the mandatory changes which needs to e done in SDK to enable above said Chipset and use our required GPIOs (. We are only using PWM supported GPIOs for output)
发表于 2024-11-1 15:36:51 | 显示全部楼层 来自 广东深圳
Are you using Telink dongle or your board. Change RAM_SIZE-MAX to 48k to see if the program works properly on the 8258 chip. If possible, you can directly burn the program with RAM_SIZE-MAX equal to 48k to the 8250 or 8253 chip to work properly
