查看: 5320|回复: 3
No joined
流光翡翠
发表于 2024-10-21 05:54:12 | 显示全部楼层 |阅读模式 来自 俄罗斯
Hello.
How to prevent a device from joining the network?
Thanks.
发表于 2024-10-21 14:05:25 | 显示全部楼层 来自 上海
You can choose any of the following to achieve it.
1. Disable network access permission through broadcast a MGMT_permit_join(with permitJoinDuration set to 0) command.
2. Change the value of tcLinkKeyCentralDefault to your private key.
流光翡翠
 楼主| 发表于 2024-10-21 14:32:16 | 显示全部楼层 来自 俄罗斯
Hello.
I need the device to not joined to the network when turned on. But to join only after pressing the button on the device itself.
Thanks.
发表于 2024-10-21 19:33:10 | 显示全部楼层 来自 上海
You can remove the bdbNetworkSteerStart related code from xx_bdbInitCb and xx_bdbCommissioningCb,
and move it to the key pressed handler.
