查看: 6634|回复: 1
[芯片专区] SWUART on TLSR8250?
发表于 2024-10-20 23:13:17 | 显示全部楼层 |阅读模式 来自 欧洲
芯片型号: TLSR8250F512ET32
I wish to send some debug data on an arbitrary pin.
This pin has no HW UART functionality.  How can I write a simple function which I can call to send data on this pin to an UART RX device?
发表于 2024-10-22 11:19:03 | 显示全部楼层 来自 上海
You should go to the driver section to ask questions about this issue
You can refer to the document: https://doc.telink-semi.cn/doc/e ... n_en/#software-uart
