查看: 4814|回复: 2
[BLE SDK] 8258
发表于 2024-10-17 17:25:47 | 显示全部楼层 |阅读模式 来自 广东深圳
SDK及版本: single connection 3.4.2.4
hi,
将8258作为slave(b85m_module) ,想通过event来获知各阶段状态,可是只有一个GAP event GAP_EVT_SMP_CONN_ENCRYPTION_DONE 在连接成功后出现,HCI event一个也没有。最麻烦的是在与master(手机) disconnect后没有任何event出现。
请问哪里有问题?
HCI 部分代码从 b85m_master_kma_dongle 中从拷贝而来:
Initial 部分:
        blc_hci_registerControllerEventHandler(controller_event_callback); //controller hci event to host all processed in this func
        //bluetooth event
        blc_hci_setEventMask_cmd (HCI_EVT_MASK_DISCONNECTION_COMPLETE | HCI_EVT_MASK_ENCRYPTION_CHANGE);
        //bluetooth low energy(LE) event
        blc_hci_le_setEventMask_cmd(                HCI_LE_EVT_MASK_CONNECTION_COMPLETE                 \
        |        HCI_LE_EVT_MASK_ADVERTISING_REPORT                         \
        |   HCI_LE_EVT_MASK_CONNECTION_UPDATE_COMPLETE  \
        |        HCI_LE_EVT_MASK_PHY_UPDATE_COMPLETE                        \
        |   HCI_LE_EVT_MASK_CONNECTION_ESTABLISH );         //connection establish: telink private event
callback 部分:
int controller_event_callback (u32 h, u8 *p, int n)
        (void)n;
        static u32 event_cb_num;
        event_cb_num++;
        printf("controller_event_callback = %x\r\n", h);
        if (h &HCI_FLAG_EVENT_BT_STD)                //ble controller hci event
                u8 evtCode = h & 0xff;
                printf("hci evtCode = %02X\r\n", evtCode);
                //------------ disconnect -------------------------------------
                if(evtCode == HCI_EVT_DISCONNECTION_COMPLETE)  //connection terminate
                        printf("HCI_EVT_DISCONNECTION_COMPLETE\r\n");
                        //blm_disconnect_event_handle(p);
#if (BLE_HOST_SMP_ENABLE)
                else if(evtCode == HCI_EVT_ENCRYPTION_CHANGE)
                        printf("HCI_EVT_ENCRYPTION_CHANGE\r\n");
                        //event_enc_change_t *pe = (event_enc_change_t *)p;
                        //blm_smp_encChangeEvt(pe->status, pe->handle, pe->enc_enable);
                else if(evtCode == HCI_EVT_ENCRYPTION_KEY_REFRESH)
                        printf("HCI_EVT_ENCRYPTION_KEY_REFRESH\r\n");
                        //event_enc_refresh_t *pe = (event_enc_refresh_t *)p;
                        //blm_smp_encChangeEvt(pe->status, pe->handle, 1);
#endif
                else if(evtCode == HCI_EVT_LE_META)
                        u8 subEvt_code = p[0];
                        //------hci le event: le connection complete event---------------------------------
                        if (subEvt_code == HCI_SUB_EVT_LE_CONNECTION_COMPLETE)        // connection complete
                                //after controller is set to initiating state by host (blc_ll_createConnection(...) )
                                //it will scan the specified device(adr_type & mac), when find this ADV packet, send a connection request packet to slave
                                //and enter to connection state, send connection complete event. but notice that connection complete not
                                //equals to connection establish. connection complete means that master controller set all the ble timing
                                //get ready, but has not received any slave packet, if slave rf lost the connection request packet, it will
                                //not send any packet to master controller
                                printf("HCI_SUB_EVT_LE_CONNECTION_COMPLETE\r\n");
                                //conn_timer = clock_time();
                        //------hci le event: le connection establish event---------------------------------
                        else if(subEvt_code == HCI_SUB_EVT_LE_CONNECTION_ESTABLISH)  //connection establish(telink private event)
                                //notice that: this connection event is defined by telink, not a standard ble controller event
                                //after master controller send connection request packet to slave, when slave received this packet
                                //and enter to connection state, send a ack packet within 6 connection event, master will send
                                //connection establish event to host(HCI_SUB_EVT_LE_CONNECTION_ESTABLISH)
                                //blm_le_connection_establish_event_handle(p);
                                printf("HCI_SUB_EVT_LE_CONNECTION_ESTABLISH\r\n");
                        //--------hci le event: le ADV report event ----------------------------------------
                        else if (subEvt_code == HCI_SUB_EVT_LE_ADVERTISING_REPORT)        // ADV packet
                                //after controller is set to scan state, it will report all the ADV packet it received by this event
                                //blm_le_adv_report_event_handle(p);
                                printf("HCI_SUB_EVT_LE_ADVERTISING_REPORT\r\n");
                        //------hci le event: le connection update complete event-------------------------------
                        else if (subEvt_code == HCI_SUB_EVT_LE_CONNECTION_UPDATE_COMPLETE)        // connection update
                                //after master host send update conn param req cmd to controller( blm_ll_updateConnection(...) ),
                                //when update take effect, controller send update complete event to host
                                //blm_le_conn_update_event_proc(p);
                                printf("HCI_SUB_EVT_LE_CONNECTION_UPDATE_COMPLETE\r\n");
                        //------hci le event: le phy update complete event-------------------------------
                        else if (subEvt_code == HCI_SUB_EVT_LE_PHY_UPDATE_COMPLETE)        // connection update
                                //2 situation can trigger this event:
                                //   1) master host trigger: by calling API  blc_ll_setPhy(...)
                                //   2) peer slave device trigger: send "LL_PHY_REQ" on linklayer
                                //blm_le_phy_update_complete_event_proc(p);
                                printf("HCI_SUB_EVT_LE_PHY_UPDATE_COMPLETE\r\n");
                        else {
                                printf("hci sub event = %d\r\n", subEvt_code);
        return 0;
GAP mask 几乎全部打开:
                        blc_gap_registerHostEventHandler( app_host_event_callback );
                        blc_gap_setEventMask( GAP_EVT_MASK_SMP_PARING_BEAGIN                         |  \
        GAP_EVT_MASK_SMP_PARING_SUCCESS                   |  \
        GAP_EVT_MASK_SMP_PARING_FAIL                                |  \
        GAP_EVT_MASK_SMP_CONN_ENCRYPTION_DONE        | \
        GAP_EVT_MASK_SMP_TK_DISPLAY | \
        GAP_EVT_MASK_SMP_TK_REQUEST_PASSKEY | \
        GAP_EVT_MASK_SMP_TK_REQUEST_OOB | \
        GAP_EVT_MASK_SMP_TK_NUMERIC_COMPARE | \
        GAP_EVT_MASK_L2CAP_COC_CONNECT | \
        GAP_EVT_MASK_L2CAP_COC_DISCONNECT | \
        GAP_EVT_MASK_L2CAP_COC_RECONFIGURE | \
        GAP_EVT_MASK_L2CAP_COC_RECV_DATA | \
        GAP_EVT_MASK_L2CAP_COC_SEND_DATA_FINISH | \
        GAP_EVT_MASK_L2CAP_COC_CREATE_CONNECT_FINISH);
 楼主| 发表于 2024-10-17 17:29:56 | 显示全部楼层 来自 广东深圳
题目没写全:8258 的事件。
 楼主| 发表于 2024-10-18 00:07:23 | 显示全部楼层 来自 广东深圳
弄明白了,重复register hci event handler了。
