查看: 6683|回复: 1
[BLE Mesh] Low power BLE Mesh device using TLSR8258F512ET48
发表于 2024-10-5 17:13:58 | 显示全部楼层 |阅读模式 来自 印度
芯片型号: TLSR8258F512ET48
Hai,
  We are planning to develop a BLE mesh node device using TLSR8258F512ET48.
I have small doubt on the power supply and current consumption. In data sheet i found range from 1.8V to 3.8 and typical 3.3v.
Can i power using 3V coin cell battery? we are planning to use CR2032 battery(220mAH capacity).
How long battery will be last?
Best Regards
Bose
发表于 2024-10-8 13:34:48 | 显示全部楼层 来自 广东深圳
The average current of a mesh low-power node with a 2-second poll interval is 50uA(TLSR8258). With an average current of 50uA, the maximum working duration for a 220mAh battery is 180 days.
(mesh LPN节点(TLSR8258)在2秒poll间隔下的平均电流为50uA,220mAH电池理论最长工作180天)。 但不建议用纽扣电池做mesh,纽扣电池在电量不足时电压飘动太大,对flash不友好
纽扣电池需要注意的是在低电量情况下,电压会拉得比较低,电压飘动大。在flash工作电压范围外操作flash,flash内容容易异常。 需要硬件保持电压稳定,比如加大电容等。
