查看: 5579|回复: 3
Some data is not applied in sampleLight module in Zigbee_BLE_Cocurrent_SDK.
发表于 2024-10-3 13:31:34 | 显示全部楼层 |阅读模式 来自 韩国
I tested one Cordinator and 10 or more smapleLight (Router mode) module.
When I comissioning and set some data to sampleLight module,
some data is not applied randomly in sampleLight module.
How to reduce data loss for zigbee ?
发表于 2024-10-8 17:50:38 | 显示全部楼层 来自 上海
Can you provide the testing conditions on your side? For example, the number of contracts issued, intervals, etc.
33
 楼主| 发表于 2024-10-29 10:36:03 | 显示全部楼层 来自 韩国
TL_YB 发表于 2024-10-8 17:50
Can you provide the testing conditions on your side? For example, the number of contracts issued ...
1 pcs x Cordinator (Ember Chip)
45 pcs x sampleLight (TLSR8258 chip)
1) Cordinator commission 10 pcs sampleLights
    -> When Cordinator send min/max level, color temperature, sensor configurations, and so on then Cordinator communicate with all samleLights correctly.
2) Cordinator commission 20 pcs or more sampleLights
    -> When Cordinator send min/max level, color temperature, sensor configurations, and so on then Cordinator communicate with some samleLights correctly but some sampleLights are not communicate with Cordinator.
发表于 2024-10-29 19:18:24 | 显示全部楼层 来自 上海
This requires packet capture analysis to see if there is environmental interference.
