查看: 5014|回复: 5
[BLE Mesh] App 组⽹后分享给Gateway后,Gateway是否还有组网功能?
发表于 2024-9-25 15:31:50 | 显示全部楼层 |阅读模式 来自 福建
SDK及版本: sig_mesh_sdk_v4.1.0.0
Gateway烧录的是8258_mesh_gw_node,使用串口和上位机“SIG_MESH_TOOL”连接。App和Gateway均可控制节点。
但是当Gateway的SIG_MESH_TOOL通过点击Scan、Prov、Provision、bind_all进行节点添加时,在bind_all处会出错,可能是什么原因呢?还是说不支持?
下面是bind_all出错的log:
<0105>15:10:50:875 [INFO]KEYBIND)start key bind and the appkey is
: c8 5a 06 1d 6c 58 5a 61 62 2b 08 1f a7 57 d5 88
<0106>15:10:50:875 [INFO]GATEWAY)HCI_GATEWAY_CMD_START_KEYBIND : e9 ff 0b 00 00 00 c8 5a 06 1d 6c 58 5a 61 62 2b 08 1f a7 57 d5 88
TX[22]:e9 ff 0b 00 00 00 c8 5a 06 1d 6c 58 5a 61 62 2b 08 1f a7 57 d5 88
<0107>15:10:50:891 [INFO]GATEWAY)cmd sendback src:0x0400 dst:0x0401,op 0880(COMPOSITION_DATA_GET): ff
<0108>15:10:50:907 [INFO]GATEWAY)cmd sendback src:0x0400 dst:0x0401,op 0880(COMPOSITION_DATA_GET): ff
<0109>15:10:50:922 [INFO]GATEWAY)HCI_GATEWAY_CMD_KEY_BIND_EVT
: 91 8a 02
<0110>15:10:50:938 [INFO]GATEWAY)HCI_GATEWAY_KEY_BIND_RSP fail
: 91 82 01
下面是Provisioning过程的全部log:
<0056>15:09:55:909 [INFO]GATEWAY)HCI_GATEWAY_CMD_START: e9 ff 00
TX[3]:e9 ff 00
<0057>15:09:56:410 [INFO]GATEWAY)HCI_GATEWAY_CMD_UPDATE_MAC
  91 88 1a d8 04 38 c1 a4  18 2b 00 75 1b 3f 02 a2  9f a1 36 95 41 0a 82 57  eb 9e 84 00 00 72 26 a2
  7f d8 02 00
<0058>15:09:56:410 [INFO]common)the unprovision beacon is : 18 2b 00 75 1b 3f 02 a2 9f a1 36 95 41 0a 82 57 eb 9e 84 00 00 72 26 a2 7f
<0059>15:09:57:693 [INFO]GATEWAY)HCI_GATEWAY_CMD_UPDATE_MAC
  91 88 34 a4 65 38 c1 a4  18 2b 00 a6 6b bf 9d 8d  4b f2 3c 8a 9c e5 1e 4e  74 52 41 00 00 72 26 a2
  7f d6 00 00
<0060>15:09:57:693 [INFO]:(common)the unprovision beacon is : 18 2b 00 a6 6b bf 9d 8d 4b f2 3c 8a 9c e5 1e 4e 74 52 41 00 00 72 26 a2 7f
<0061>15:10:01:292 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_SET_ADV_FILTER: e9 ff 08 1a d8 04 38 c1 a4
TX[9]:e9 ff 08 1a d8 04 38 c1 a4
<0062>15:10:01:308 [INFO]:(GattProv)CScanDlg::provision link:the device uuid is
: 75 1b 3f 02 a2 9f a1 36 95 41 0a 82 57 eb 9e 84
<0063>15:10:03:447 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_GET_PRO_SELF_STS  : e9 ff 0c
TX[3]:e9 ff 0c
<0064>15:10:03:456 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_GET_SNO : e9 ff 0e
<0065>15:10:03:472 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_PRO_STS_RSP provisioned
: 91 8b 01 a9 8a 6a 60 90 91 3a f8 d7 64 41 f9 a3 bb 4c 44 00 00 00 00 00 00 01 02 04
<0066>15:10:03:472 [INFO]:(common)gateway json init start
<0067>15:10:03:472 [INFO]:(common)node_idx=2, vc_uuid=: 3c 2a 73 af 03 66 48 36 a5 b5 7c 4c 6f 2a 15 06
<0068>15:10:03:487 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_SEND_ELE_CNT
: 91 8c 02
<0069>15:10:03:503 [INFO]:(common)save tx cmd sno to INI: 0x000005(5)
<0070>15:10:39:644 [INFO]:(GattProv)start provision for the device
<0071>15:10:39:644 [INFO]:(common)is this new address 0x0401 already used in VC node info ?
<0072>15:10:39:644 [INFO]:(common)obj_adr 0x0401, not found in VC node info
<0073>15:10:39:659 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_SET_NODE_PARA : e9 ff 0a a9 8a 6a 60 90 91 3a f8 d7 64 41 f9 a3 bb 4c 44 00 00 00 00 00 00 01 01 04
TX[28]:e9 ff 0a a9 8a 6a 60 90 91 3a f8 d7 64 41 f9 a3 bb 4c 44 00 00 00 00 00 00 01 01 04
<0074>15:10:40:441 [INFO]:(GATEWAY)the node link open cmd is
<0075>15:10:40:644 [INFO]:(common) =============  GATEWAY  >>>>>>>>>>>>>>>>>> IUT===================
<0076>15:10:40:644 [INFO]:(common)prov invite cmd: 00 00
<0077>15:10:41:300 [INFO]:(common) =============  GATEWAY  <<<<<<<<<<<<<<<<<< IUT===================
<0078>15:10:41:300 [INFO]:(common)prov capa cmd: 01 02 00 03 00 00 00 00 00 00 00 00
<0079>15:10:41:316 [INFO]:(common) =============  GATEWAY  >>>>>>>>>>>>>>>>>> IUT===================
<0080>15:10:41:316 [INFO]:(common)prov start cmd: 02 01 00 00 00 00
<0081>15:10:41:972 [INFO]:(common) =============  GATEWAY  >>>>>>>>>>>>>>>>>> IUT===================
<0082>15:10:41:972 [INFO]:(common)prov pubkey cmd: 03 83 5d ed 42 35 05 97 f8 1c bd e0 27 13 79 db 1e b1 ed 82 d8 9c bd 7b 1c 66 68 b0 75 cf eb ec
<0083>15:10:42:801 [INFO]:(common) =============  GATEWAY  <<<<<<<<<<<<<<<<<< IUT===================
<0084>15:10:42:801 [INFO]:(common)prov pubkey cmd: 03 b6 1f 8b a3 f7 5f 5b 83 87 01 50 be 04 9a 24 bd 2b d4 f5 b0 59 13 38 6f 89 b9 6c 9d 01 85 19
<0085>15:10:42:817 [INFO]:(common) =============  GATEWAY  >>>>>>>>>>>>>>>>>> IUT===================
<0086>15:10:42:817 [INFO]:(common)prov confirm cmd: 05 6b cd 75 7d 15 e9 af de ba 11 f8 91 0f a0 1f ac fe 9b 5c cb de 60 2c 30 c7 98 fb b8 77 6f ab
<0087>15:10:43:631 [INFO]:(common) =============  GATEWAY  <<<<<<<<<<<<<<<<<< IUT===================
<0088>15:10:43:631 [INFO]:(common)prov confirm cmd: 05 ee 7d 47 58 08 a7 8f 02 29 1e fe e5 f7 20 26 e7 86 89 4a a5 3a ba c6 40 42 5e 94 89 38 6e 3b
<0089>15:10:43:646 [INFO]:(common) =============  GATEWAY  >>>>>>>>>>>>>>>>>> IUT===================
<0090>15:10:43:646 [INFO]:(common)prov random cmd: 06 98 aa 48 c6 26 eb bd 22 4f 5b 85 30 91 db e2 19 5a 4f aa e2 b7 0c a9 f3 81 d2 17 1a 78 cd 36
<0091>15:10:43:834 [INFO]:(common) =============  GATEWAY  <<<<<<<<<<<<<<<<<< IUT===================
<0092>15:10:43:834 [INFO]:(common)prov random cmd: 06 60 af 24 44 16 e9 e7 62 26 a9 3d 6e 16 15 b8 ca 99 e3 9d 74 d1 ee 5e e8 dd 49 91 3a 87 ad 99
<0093>15:10:43:850 [INFO]:(GATEWAY)HCI_GATEWAY_RSP_UNICAST
: 91 80 01 04
<0094>15:10:43:865 [INFO]:(common) =============  GATEWAY  >>>>>>>>>>>>>>>>>> IUT===================
<0095>15:10:43:865 [INFO]:(common)prov data cmd: 07 28 d9 47 3c f4 64 f8 d2 b6 5d 80 36 c7 27 c5 24 52 85 1a 81 aa dc e1 fb a9 01 8a 14 6c 86 82
<0096>15:10:43:990 [INFO]:(common) =============  GATEWAY  <<<<<<<<<<<<<<<<<< IUT===================
<0097>15:10:43:990 [INFO]:(common)prov complete cmd: 08
<0098>15:10:44:006 [INFO]:(GATEWAY)the node link close cmd is
: 0b 00
<0099>15:10:45:993 [INFO]:(iv_update)gateway dongle report sno: 0x000005, iv trigger flag: 0, iv index:
: 00 00 00 01
<0100>15:10:46:007 [INFO]:(common)save tx cmd sno to INI: 0x000005(5)
<0101>15:10:46:012 [INFO]:(common)clear import JSON flag
<0102>15:10:46:037 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_SEND_NODE_INFO
: 91 8d 01 04 02 00 83 59 fa 6a 1f 21 be 7c f9 06 82 95 a1 c3 59 2e
<0103>15:10:46:053 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_PROVISION_EVT
: 91 89 01 01 04 1a d8 04 38 c1 a4 75 1b 3f 02 a2 9f a1 36 95 41 0a 82 57 eb 9e 84
<0104>15:10:46:060 [INFO]:(log_win32)json_add_net_info_doc
<0105>15:10:50:875 [INFO]:(KEYBIND)start key bind and the appkey is
<0106>15:10:50:875 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_START_KEYBIND : e9 ff 0b 00 00 00 c8 5a 06 1d 6c 58 5a 61 62 2b 08 1f a7 57 d5 88
<0107>15:10:50:891 [INFO]:(GATEWAY)cmd sendback src:0x0400 dst:0x0401,op 0880(COMPOSITION_DATA_GET): ff
<0108>15:10:50:907 [INFO]:(GATEWAY)cmd sendback src:0x0400 dst:0x0401,op 0880(COMPOSITION_DATA_GET): ff
<0109>15:10:50:922 [INFO]:(GATEWAY)HCI_GATEWAY_CMD_KEY_BIND_EVT
: 91 8a 02
<0110>15:10:50:938 [INFO]:(GATEWAY)HCI_GATEWAY_KEY_BIND_RSP fail
: 91 82 01
发表于 2024-9-26 11:28:54 | 显示全部楼层 来自 广东深圳
1.直接看 log 显示的原因是 gateway 发送 composition data get 命令给节点,gateway 未收到 节点 回复的 composition data,所以触发异常退出。
2.先确认,只有 gateway node 节点 和 未配网节点的时候,组网是否正常。先不要 引入 App。
 楼主| 发表于 2024-9-27 09:15:23 | 显示全部楼层 来自 福建厦门
TL_HSF 发表于 2024-9-26 11:28
1.直接看 log 显示的原因是 gateway 发送 composition data get 命令给节点,gateway 未收到 节点 回复的 c ...
只有 gateway node和未配网节点,没有导入JSON文件,直接组网是正常。
发表于 2024-9-27 14:41:43 | 显示全部楼层 来自 广东深圳
你的App 和 gateway nonde 之间的关系是什么,是怎么相互分享数据的?
把你的场景描述更清晰一些
 楼主| 发表于 2024-10-10 09:16:32 | 显示全部楼层 来自 福建厦门
把你的场景描述更清晰一些 ...
手机APP组网其它设备节点,导出JSON文件,通过串口和SIG_MESH_TOOL加载进gateway node,此时App和Gateway均可发消息控制设备节点。
然后gateway node通过SIG_MESH_TOOL扫描其它未配网设备,通过点击Scan、Prov、Provision、bind_all进行节点添加时,在bind_all处会出错。
发表于 2024-10-15 19:11:42 | 显示全部楼层 来自 广东清远
这个问题,是网关分配给节点的地址不对,分配给节点的地址应该是   网关的地址+网关的元素个数。  内部试了从分享导入时往json文件写入网关默认composition data的时候,没刷新从网关获取的实际元素个数(默认是1),而8258_gw_node的元素个数是2,导致分配给节点的地址落在网关地址范围内,需更新上位机。   没特殊需求的话直接用8258_mesh_gw工程就行,此工程默认元素个数为1 。
sig_mesh_tool.exe
4.88 MB, 下载次数: 2
