查看: 3562|回复: 3
[Audio] Setup Audio Line-In to Speakers
发表于 2024-9-18 05:13:21 | 显示全部楼层 |阅读模式 来自 哥斯达黎加
芯片型号: B91 Generic Starter Kit
驱动SDK版本: Telink_RDS_v323
Hello,
How can I setup audio 24bits 48k from the line-in to Speakers(DACs)?
I need setup the B91 Generic Starter Kit  to get audio from the Line-In to the the Audio output
//audio parameters
#define    AUDIO_BUFF_SIZE    4096
volatile unsigned short AUDIO_BUFF[AUDIO_BUFF_SIZE>>1] __attribute__((aligned(3))); ///Is it correct 3 instead 4 on aligment?
void Audio_user_init()
        audio_init(LINE_IN_TO_BUF_TO_LINE_OUT,AUDIO_48K,STEREO_BIT_24);
        audio_rx_dma_chain_init(DMA2,(unsigned short*)AUDIO_BUFF,AUDIO_BUFF_SIZE); /// is unsigned short  correct?
        audio_tx_dma_chain_init (DMA3,(unsigned short*)AUDIO_BUFF,AUDIO_BUFF_SIZE);
        audio_codec_dac_power_on(); // Is it required?
        audio_codec_adc_power_on(); // Is it required?
            audio_rx_dma_en(); // Is it required?
            audio_tx_dma_en(); // Is it required?
Also, Can I send the audio input simultanestly to speaker and save on memory?
Regards,
Heiner
璀璨钻石
发表于 2024-9-18 17:03:19 | 显示全部楼层 来自 广东深圳
* en   : 1-enable, 0-disable
* Gain : 0dB ~ -31dB(0x00~0x1f);
* ain  : 0-Left, 1-Right
void side_tone_en(int en, uint8_t gain, uint8_t ain)
        if(en)
                REG_ADDR8(0x1202d8) = 0x80 | (gain & 31);
                REG_ADDR8(0x1202a0) = 0x41;
                REG_ADDR8(0x1202a4) = ain ? 0x04 : 0x01;
                REG_ADDR8(0x1202a0) = 0x40;
                REG_ADDR8(0x1202a4) = 0x01;
                REG_ADDR8(0x1202a0) = 0x00;
        else
                REG_ADDR8(0x1202a4) = 0x00;
可以通过上面这个函数把MIC的数据通过硬件直通的SPK
璀璨钻石
发表于 2024-9-18 17:05:01 | 显示全部楼层 来自 广东深圳
如果要改成24bits   需要将AUDIO_BUFF这个数组改为32位的,并且依然是4字节对齐  因为C语言只有8 16 32位  没有24位的变量
璀璨钻石
发表于 2024-9-18 17:09:29 | 显示全部楼层 来自 广东深圳
其他的初始化抄的 和audio demo一样就好了  如果需要软件上声音从MIC到SPK,可以做个简单处理,开个10ms定时器  每10ms把mic里面的buff推送的SPK即可,注意,这个定时器需要严格10ms并且要精确控制读写指针才不会有杂音
