查看: 4021|回复: 2
[BLE Mesh] Device name in SDK mesh
发表于 2024-8-27 10:51:13 | 显示全部楼层 |阅读模式 来自 越南
芯片型号: TLS8258
SDK及版本: sig_mesh_sdk, version v3.3.3.6
I have a problem with the name of the device when playing advertising. I named it VCONNEX_MESH_XXXX. But when playing the adv, the name is not displayed, when I connect to the device, it displays the name.
 楼主| 发表于 2024-8-27 11:00:12 | 显示全部楼层 来自 越南
发表于 2024-8-28 09:42:17 | 显示全部楼层 来自 广东深圳
Your name is only set in the ATT table, which requires a successful connection to retrieve it, as expected. The contents of the ATT table are read through the service discovery process after a successful connection. Before connection, it will not be read.
