查看: 6380|回复: 1
[BLE SDK] [转载] What is the maximum size of data passed to the bls_ll_setAdvData functio
发表于 2024-8-26 19:34:56 | 显示全部楼层 |阅读模式 来自 上海
转自旧论坛作者: Slacky
Hello.
What is the maximum size of data passed to the bls_ll_setAdvData function?
I use Bluetooth LE Single Connection - SDK V3.4.2.1_Patch_0006.
With a size of 27 bytes, the return code is 0 (BLE_SUCCESS).
With a size of 35 bytes, the return code is 0x12 (HCI_ERR_INVALID_HCI_CMD_PARAMS).
 楼主| 发表于 2024-8-26 19:35:02 | 显示全部楼层 来自 上海
hi,
  the adv packet max lenght is 31 bytes,if you need 35 bytes adv ,you can use extend adv, refer to b85m_feature_test demo ,also you can download hand book form wiki http://wiki.telink-semi.cn/wiki/chip-series/TLSR825x-Series/
