查看: 1655|回复: 1
Can I exchange a network to another network ?
璀璨钻石
发表于 2025-7-31 15:24:14 | 显示全部楼层 |阅读模式 来自 韩国
芯片型号: tlsr8258
SDK及版本: telink_zigbee_ble_concurrent_sdk v2.4.1.0
I want to change a network to another network.
1. I commission a sampleLight(A) to a zigbee network(F).
2. I want to change zigbee channel and network id and security id of a another zigbee nerwork(G) on the sampleLight(A).
3. Thus I want to join the sampleLight(A) to another zigbee network(G).
How to work it ?
Can I get flash address of a zigbee network information (channel number, network id(pan id, ext pan id), security id, and so on) ?
发表于 2025-8-26 16:27:48 | 显示全部楼层 来自 上海
My suggestion is to let it leave the previous network and then join the new network.
You can get the g_zbInfo (PIB/NIB...) and ss_ib through this method
  1. nv_flashReadNew(1, NV_MODULE_ZB_INFO, NV_ITEM_ZB_INFO, sizeof(zb_info_t), (u8 *)&g_zbInfo);
复制代码
  1. nv_flashReadNew(1, NV_MODULE_APS, NV_ITEM_APS_SSIB, sizeof(ss_ib), (u8 *)&ss_ib)
复制代码
