查看: 2081|回复: 1
[BLE SDK] BLE HID
发表于 2025-7-24 14:25:21 | 显示全部楼层 |阅读模式 来自 广东
芯片型号: 8208
Hi is the report rate for BLE HID is it fixed to (125 Hz, max 133 HZ) or is it configerable and where can view them. Can someone guide me to it?
发表于 2025-7-25 09:24:24 | 显示全部楼层 来自 上海
It depends on connection interval.
If you uses the peripheral device, you can use bls_l2cap_requestConnParamUpdate to request CONN_INTERVAL_7P5MS and latency.
If you uses the central  device, you can use blm_ll_updateConnection to set CONN_INTERVAL_7P5MS and latency directly.
